replacing front seat
ducki
vr commodore
:bang: i have managed to snap the weld that holds the seat to the runner, because of that i have to replace the front seat... being the indoor decorating type and knowing nothing about bolts could someone please tell me (in idiot terms) how to change the seats over??:thumbsup:
Patrio7
3Y3 K4N 5P33K 1337.
35
Perth, Como
'96 S1 VS Exec
the rails should have four allen key screws/bolts, pretty sure its a case of undoing said four screws / bolts and then presto your seat is out.
from there you can either get new rails [ wrecker ] or replace the seat entirely ( maybe go a VS S2 seat, its slightly more "buckety" ( better side leg support slightly deeper back )
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
You could always reweld the rails.
theburna
Wyee
VR Statesman
Easy as Campessi
One of the easiest jobs.
If you have a height adjuster jack it up, there are 4 allens bolts, one in each corner.
Pull the seat out of the car and turn it upside down and take out the 4 allen bolts, again one in each corner.
Go to the wreckers and get a replacement set of runners and fit in the reverse.
A common problem with people who lean the seat back too far when driving.
Please note that they cannot be repaired as the heat weakens the metal.:wax:
