Replacing fuel pump in a VR
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by deathsminion, Feb 1, 2005.
  1. deathsminion
    deathsminion Chrgd,Coold,Twinthrot'in
    GT42R forced JZA80 Supra and VT Wagon
    Ok, I've already found this thread: http://forums.justcommodores.com.au/showthread.php?t=5836
    But it didn't quite cover everything. Now, is the fuel pump behind the rear right wheel, above the petrol tank? That's about the only thing I could find. If it is, then does it mean you have to remove the tank? Or is there a simpler way?
    Any pics would be most helpful as well.
    Cheers in advance
    -Luke
  2. Darren
    Darren Administrator Staff Member
    HSV Clubsport R8 E2 M6
    The fuel pump is located within the petrol tank. On the front of the tank (facing the front of the car) you will see I think it's around the 6 - 8 10mm bolts or thereabouts holding the fuel pump in place.
    It's awkward but you can get away with not removing the fuel tank although does help if you can lower it slightly.
    I'm not sure whether I mentioned it in the how-to but drain the tank as low as possible otherwise it will make a huge mess as you could imagine.
    If you're still unclear of it's location I should be able to take photo of it's exact location if you wish.
  3. deathsminion
    Thanks for the quick reply.
    Photo's would be great if they aren't too much hassle. Holden are selling new pumps for $180, so I thought it would be better to fit it myself, rather than fork out $400 to the only mechanic I trust with my car.
    - Luke
  4. deathsminion
    Ah, never mind mate, I found it. Cheers for your help.
  5. Darren
    Great to hear! I just thought, my sister is heading up to QLD for a week or so and she'll have my camera which would make it difficult to get some photo's of it.
  6. undertaker07
    undertaker07 Guest
    the fuel pump is in the tank on the right hand side , drain the entire tank but is easier if you have a hoist total cost about $150
  7. sk1p
    sk1p Guest
    mwuahaha i can get a fuel pump for 100 bucks :) hehe, gl anyway
  8. xcop
    xcop New Member
    vr x cop
    my vr has a full tank of fuel and the fuel pump is stuffed! what is the easiest to drain the tank?
  9. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Ding ding ding, we have a winner. 6 YEAR thread dig:balloons:
    But yes to answer to ur question is to simply put a large bowl under the fuel tank and just start undoing some bolts on the fuel pump hole. Least time wasting and it gets you started on the job. Dont forget a new gasket before you start the job.
  10. Nenita
    Nenita New Member
    SA
    VR
    I bought a 1994 Vr Commodore just recently, a gas tank has been put into the car but as soon as we drove it home it was empty. The car won't start and the ex owner disconnected the fuel pump. I have no idea how to gain access to the fuel tank to get to the fuel pump. Will jacks give enough height to do this properly because the fuel tank might (or might not) need to be drained? Is it worth paying the money for a mechanic to do this job? Is the fuel tank located on the drivers seat side or the passenger side? I don't want to replace anything I just want to connect the pump, so is it just one thing I'd need to connect or will I find a whole heap of stuff that needs connecting? I know very little about cars and this is my first one so I want to do all of this right.
    If someone could give me some answers that'd be great.
  11. Beav
    Beav New Member
    Emerald
    93 vr commodore
    I have a 93 vr commodore, repaired my fuel tank on Thursday afternoon the fuel is within the fuel tank and the bolts are 7mm. It is awkward spot, it faces the diff centre
  12. Beav
    Beav New Member
    Emerald
    93 vr commodore
    It's a plug
