GEP
- Jun 30, 2019
- 46
- 5
- 8
- Age
- 37
- Location
- Australia
- 2003 VY V6 BERLINA SEDAN
Hi JC users, (sorry for the long write up)
Ive used this forum many times for tips and solutions to problems and have found the threads on here very helpful, especially with the how-to guides. I have 'bookmarked' all the guides I will need for this operation on my car but still have a few questions.
Ive brought all the parts I need for this redo including a full Matsumo intake (alloy) and header gasket set, new water pump, new tensioner, new pcv valve, new thermostat, new idler pulleys, all new radiator coolant hoses (x6), new heater tap (genuine GM, new oil filter (genuine GM, new header bolts and new rocker cover gaskets and grommets.
I have also purchsed castrol 10w-30 ultraclean, CRC cleaner, LiquoMoly for rubber seals and an assortment of other misc stuff like gloves.
I do have a few questions that I hope some experienced users might be anle to guide me on. Im deciding which silicone Permatex sealant to use for the valley of the intake, there copper, red, blue, black, grey..its all very confusing. I see many people use black but when I spoke to the supercheap auto guy he said the 250C max temp isnt enough for the intake manifold. My concern with the black is also oil degredation, however reading on the Permatex website it says that ultra black is just fine for intake ends. So im confused.
Also I notice that when I do an oil change my lifters and that whole assembaly inside is a brownish color to everything. I dont notice any dark sludge but it just has a ting to it, what would be a good way to clean that without taking it all apart as I dont have the tools or expertise messing with those lifters and springs or should I just leave well enough alone.
My knowledge of working on cars is probably abit above average, I recently changed the trans fluid and oil (not a flush), flushed powersteering fluid, changed differential fluid and ofcourse the regular oil changes. To the car side of things I changed the brakes and rotors last year. I have the workshop instructions on this headgasket and inlet gasket change over, so any tips woild be great. Just abit nervous and its cost me close to $400 for parts so far, so I dont want to have to repeat this.
Im pretty sure my cars got a blown intake gasket as many years ago I noticed oil in the coolant and the engine area is covered in oil, which Ill be cleaning off too.
Thanks guys for you tips and encourgment.
CAR DETAILS:
SEDAN
2003 VY BERLINA ECOTEC V6
260,000KMS
Owned the car since 80,000 and have not done anything to it except oil changes and the mentioned items above.
CAR DETAILS:
SEDAN
260,000KMS
