GEP
- Jun 30, 2019
- 57
- 7
- 8
- Age
- 37
- Location
- Australia
- 2003 VY V6 BERLINA SEDAN
So I got started this afternokn, around 3PM. Just finished now. Cleaned and degreased engine, trottle body, plenum and LIM. Its bedn a lot more work then I thought, and somewhat stressful.
Everything was going okay until I went to unbolt the plenum from the LIM. Wgen I went to undo the first bolt the socket fell off the wrench and straight down the hole into where the little valve things go. This happen twice, I was nearly beside myself with stress.
The first socket peice was somewhat easy to get our, the second however made its way behind the valve stem...it was wedged in there and I had nothing small and long enough to geab it. So I went to supeecheap and got a long nose pliers. After some considerable anxiety I manged to get the other socker peice out. I thought Id have to remove the heads to get this out, which I had not been prepared for.
Tomorrow I have to clean the throttle valve, some bolts and the intact manifold surface. Depending on how I feel I might start reassembly.
