Replacing instrument panel globes?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ninja, Jun 14, 2005.
  1. ninja
    ninja Guest
    My instrument panel doesn't completely illuminate. The temp guage on the right hand side is not lit up, but the rest of the panel is. My question is, can I replace the globe(s) without taking the whole instrument panel out to get to the globes? I've had a good look under and I just can't see where the globes go. I can see the little globes that light up all the warning lights, but I'm buggered if I can see the others. Anyone?
  2. smw757
    smw757 New Member
    VS2 Berlina 5.0L
    Instrument cluster globes
    My Berlina has 147k on the clock and both temp and fuel lights have stopped working - probably a pretty common problem! Anyone help us out!!
  3. =Calais v8=
    =Calais v8= Holden Tech Apprentice
    S/E Melbourne
    VSII 5.0L Calais, 13b ae71
    also can you have different coloured dash lights? like blue or white instead of crappy green? if so, where do you get them
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Take out the cluster
    I am assuming that it is a level 1 or 2 cluster. There are three lights set into the back of the cluster. The warning lights, etc are set on the bottom of the cluster.
    To change the lights, you will have to remove the cluster. Then it is an easy job. I would replace all the 3 lights if I were you, just to avoid having to pull the cluster again too soon.
    If you are unsure on how to remove the cluster, try:
    http://forums.justcommodores.com.au/showthread.php?t=8844&highlight=cluster
    Good luck.
  5. ninja
    ninja Guest
    Thanks for that Fekason, I was trying to avoid pulling the cluster out, but I will just have to bite the bullet.
