Hi all, I'm need to change my leeds on VS 3.8 auto , Just having a look ,do need to remove the alternator to replace the leeds as there is no way i can pull them thru or even remove the conduit . It seem like a very tight gap. Such a simple job may take hours!!! Has anyone else had this issue? Any help will be much appreciated Thanks Darker
It's been a long time since I replaced the leads on a V6 bit I'm pretty sure I had to remove, or at least loosen the alternator to run the leads the correct way.
Remove serpentine belt Remove lower 13mm bolt from alternator Remove 10mm bolt from support on top of alternator (may also need to loosen it the other end) Loosen top 13mm bolt on alternator and just swing it on its axis
