[VZ] Replacing plugs on your alloytec( Not dial up friendly)
SLIVZ
33
koo wee rup
05 VZ Calais 3.6
Things Youll Need.
Music
10mm Socket
13mm Socket
16mm Plug Socket
Multi Grips or Pliers
Phillips head
Flat Blade screw driver
6 Spark Plugs(i got mine from holden but you can get them from Autobarn aswell)
1 pair of inlet Manifold Gaskets
First things First, You have to pull of these 2 Vaccum Hoses
Undo this Bold with your 10mm socket
Undo the 3 screws holding the Airbox lid on Using a Phillips head
Remove radiator Cover by using your Flat bladed Screw Driver
Now Unplug your AFM
Undo the Clamp on your Induction pipe with a small shifter, Unplug the Throttle body(underneath), And take off the vaccum hose on the left hand side
Use Pliers to squeeze the clamp on the Master Cylinder vaccum hose and pull it off, Unplug the to plugs just behind the manifold and undo the 6 13mm bolts holding down the manifold
You are now faced with this
Start by undoing the 6 10mm bolts Holding down the Coil packs, they should now just pull out and now use your 16mm plug socket with extension to remove the plugs
Now clean the Runner gasket area with some Metho or petrol and a razor blade( WARNING: TRY NOT TO DIG THE BLADE INTO THE SURFACE AS IT WILL CUT GROOVES INTO EASILY AS ITS ONLY ALLOY) once that is done Place new Gaskets and reverse all the steps and your done
eirkal
2004 VZ Commodore
when replacing the inlet manifold gaskets, do you use sealant before putting the manifold back on??????
VKCOMMO
Carpark Mechanic.....
Springwood, NSW
Wouldnt hurt, Since it is like $5 for a tin of it
good write up
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
good write up
There's no need for sealant as the gaskets have locating lugs to stop them moving around and once the bolts are in, they wont move.
acarmody
Donati..Whoa Green
VX Berlina
God bless my Ecotec. I remember trying to change the plugs on my brothers Camry, wasn't that a royal PITA.
satos
VZ Berlina
Excellent tutorial,will save a lot of time when the time comes to change the plugs.
Thanks
edals
Good How to Mate,
I Had no clue with these and doing a service. No wonder i have never seen the plugs cause did not know you had to pull the whole air intake off lol
VzVzVz
Port Melbourne
VZ S ute
You make it look too hard mate, just undo the plennum bolts and shove a couple of blocks of wood in between the plennum and manifold. Doesnt matter if you mess up the old gasket, coz it gets replaced anyway. Dont remove the whole thing.
airstyle
North shore NSW
VZ SV6
He didn't say it was the quickest way, just a way he's done it without hassle. A full R&R makes you learn a lot more than just prying away what's in the way in the hope you'll have space to actually work in.
And I'm pretty sure he was commenting on the lower intake manifold, not the gasket, the gasket is probably paper based, the lower plenum is alloy!
Does anyone have the part numbers for the inlet manifold gaskets? Are they the same between the 175, 190 and 190 '05 update?
Cheers and thanks SLIVZ for the how-to, pictures always make doing **** in the engine bay alot easier :)
Greg.
