Replacing Tail Light and Drivers Side Door Lock and Latch
Zedlen
VT Executive S1
My cars getting a road worthy soon and I need to replace a rear tail light and lock and latch on the drivers side door. 98 Exc Vt. Any help ?
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Help with what? Installation, sourcing??
Zedlen
VT Executive S1
I changed the tail light thanks anyway.
How do I take out the latch on the door ? Where do I begin ?
Then installation.
Thanks in adavance
Static89
I Am Ironman.
35
Sherwood QLD
VT Berlina S1
the latch? as in the handle or the prt that clicks into the body?>
Zedlen
VT Executive S1
The lock itself works but the handle won't open the door.
Mick1988
W.A. Cruise Moderator
35
Perth, Western Australia
www.sarichtechnology.com
Too many to list......
you have to take the door skin off and remove the handle from the inside. Depending how bad it is, you might be able to modify it to get it working. If not, you'll be able to pick one up second hand cheap enough and fit it.
Zedlen
VT Executive S1
Thanks, how hard is it to take the door skin off ?
mofo sixx
VT 5.0 auto
easy
you will see screws right round the outter edge of your trim (i say trim not skin)
start by unscrewing those,
then you need to pop out the little orange lug on your door lock/button,
use a pocket knife or something similar, & carefully pop it off
remove the button then you will see a screw in the plastic section behind where the button sits
*could be a screw around the inner handle, cant remember*
thats all there is to it trim should come off
Zedlen
VT Executive S1
easy
Thanks sixx,
Does anyone know how to change handle or have any links to a site with instructions, I don't want to mess with central locking without knowing what I'm doing ?
Or if not replace it, how it can be fixed ? its only the lever itself that wont open the door.
