Replacing valve springs
villn808
What sort of mileage should you get out of a set of valve springs?
I have PSI single beehives. Being single I’m paranoid about one breaking and dropping a valve. I’m pretty anal when it comes to maintenance.
Springs are rated to .625” lift and my cam .598” .602”
You don’t hear of people changing them much as a maintenance item.
EYY
VS Statesman
Depends on ramp rates, oiling (heat kills them too), lift, max rpm etc etc.
There was a good thread on av8 if you wanted to do a search
villn808
Sorry what do you mean by av8?
Edit: think I’ve found what you meant. Can you remember the name of thread? A lot coming up to do with valve springs.
Skylarking
123
Downunder
Commodore Motorsport Edition
Immortality
Staff member
Sth Auck, NZ
If you are worried about dropping a valve than the only way to eliminate that risk is to fit a set of double springs.
How many stories do you hear of engines dropping valves when fairly much every modern OEM runs beehive style springs including the factory performance GM LS offerings.
villn808
Yea when I originally got cam done I didn’t specify duals, (I thought he would use duals) Will definitely be going with them now.
Immortality
Staff member
Sth Auck, NZ
PSI is a good brand so I wouldn't be to concerned with them breaking. There is still a huge debate about single Vs double springs and doubles certainly do give a safety factor a single doesn't have but then a properly spec'd single will outperform a dual spring. Personally, I like beehive springs.
villn808
Yea I have read that too about singles vs duals. There’s just always that thought in the back of my head about one breaking.
Tuner says he’s never had one fail.
Eventually I’ll build a motor but the SBE combo is still so strong even at 470rwkw and I want it to last as long as possible.
