VL-VP-VT
- Jun 30, 2005
- 88
- 1
- 0
- Age
- 45
- Location
- Dusty Dubbo
- WH II Statesman GEN III
It should be a fairly easy task to complete, as there is already everything there for you, I did an auto to manual conversion by myself in a VK
it was a pain doing the clutch pedals and cables etc etc, but yeah don't forget the bush that goes into the rear of the crankshaft, ( or make sure there isn't already one in there and pushed all the way in, as I think you can install an auto with this bush still in place, if the bush is in there but pushed all the way back you will have to move it flush with the end of the crank where the flywheel bolts on, if you need to do this fill the hole with grease and find a bolt or something that fits inside the bush fairly snug and hit it with a hammer this will move the bush out.)
if you have plenty of room under the car, you can do the bolts on top of the gearbox from under the car, I used like 4 or 5 long socket extensions, was much easier than reaching in from the engine bay.
my biggest mistake was putting an aussie 4 speed in first, lasted about 8 months, till I dropped all gears but 1st and reverse. got hold of an M21 from a v8 and put that in just had to change the bell housing.
