Resetting SRS Air bag warning
Discussion in 'VY Holden Commodore (2002 - 2004)' started by v6vy, Dec 19, 2007.
  1. v6vy
    v6vy New Member
    vy
    I have removed my steering wheel and air bag to fit the satin inserts.
    I now have the air bag warning on permanently even though I have put everything back in place.
    Does anyone know how to reset the warning ?
    Yes I am sure its back together properly.
  2. dufus
    dufus Donating Member
    rickshaw
    I think that you have to go into a Holden workshop and get them to reset the warning.
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Yep, can only be reset by Holden. You must have turned the key on while the airbag was disconnected.
  4. v6vy
    v6vy New Member
    vy
    Yeah, I read that in one thread somewhere too, but I had the battery disconnected until I was finished.
    It would be nice to be able to reset the flag without the General's assistance.
  5. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Ahhh...both terminals or just the negative? The positive has to be disconnected to totally disconnect power from the car. Also, the airbag capacitor will still have power stored in it even with the battery disconnected. Good practice is to disconnect the battery and turn the headlights on. This will discharge the capacitors so that if the key was turned on, it won't set he warning light.
  6. nEb.
    nEb. New Member
    04' VY II Acclaim
    i had this same problem when i upgraded my steering wheel to the SS leather one with the nice satin chrome spokes, holden asks for 65 bux i think, took it down to the local mechanic who happened to have a dyagnostic computer/machine thing (same **** that holden uses) set me back 20 bux :D
    take that GM!
  7. v6vy
    v6vy New Member
    vy
    Ok,
    when I took the steering wheel off again I found that the yellow plug, the detonator ?, was not seated properly.
    I had just plugged it in but had not pressed it in to lock it.... d**khead...
    So unless any one knows how to reset it I will have to go the GM route....
  8. dufus
    rickshaw
    Im almost 100% sure that there is no way that you can reset it yourself, so you are going to have to go the Holden route.
  9. v6vy
    v6vy New Member
    vy
    thanks for the response guys - it will be a new year thing I think
