So true... thanks again mate!No worrys that's what the forums are for
I think for that price I might just a pay the little extra and get the problem sorted out completely. I guess if the device was under $150 I wouldv considered it.We went through this only 2 months or so ago. That scan tool won't clear or even show the SRS fault, however there is one thats about $400 the cheapest ive seen called the Maxitel SRS and oil light reset. We almost bought one ourselves to reset an srs light but got a mechanic to do it in the end.
Thanks Rick... I appreciate your reply. Im terribly busy over the next two weeks but when I get to it, I will certainly check out that plug you referred to. Not even Holden themselves who attempted to solve the problem suggested this. They just kept resetting the damn thing.Hi guys,
Newbie on the forum but felt like putting sticking my nose in on this one.
In my opinion the SRS is probably being triggered by a faulty wire under one of the front seats.
In my VY there is a yellow & orange plug on the left of the passenger seat which, if unplugged while the key in on will trigger the fault.
I found this out the hard way when I installed an amp under the passenger seat.
I am a software developer and thinking of buying the elcheapo diagnostic tool from ebay which really is just a connector and USB to connect to a PC. It seems the software supplied only matches up any diagnostic code with a database. I am wondering if I can write something to do some basic resets.
From what I can gather there are lots of blokes who get the SRS warning from installing amps, water spills during detailing or installing new seats.
According to the book you can hit the mode button to reduce the size of the warning on your cluster but until you get it reset from Holden your airbags and srs are disabled.
Rick
to clarify, when it does the start up check it gets to the check then beeps and illuminate an SRS Failure warning. Hitting mode clears that from the cluster, same as the low fuel warning, but a bright red SRS light stays on in the left hand corner and as mentioned its disabled.According to the book you can hit the mode button to reduce the size of the warning on your cluster but until you get it reset from Holden your airbags and srs are disabled
Great to know. I dont think I would want to use a mechanic who doesnt have the technology to scan these problems on widely used cars as from Holden.most modern work shops have scan tools that can scan srs systems. I have one that i use daily and its not a tech2, tho do have access to as tech2 without the holden repair costing of diagnosis![]()
Yep, thats what happens lolto clarify, when it does the start up check it gets to the check then beeps and illuminate an SRS Failure warning. Hitting mode clears that from the cluster, same as the low fuel warning, but a bright red SRS light stays on in the left hand corner and as mentioned its disabled.
