Retreads - Are they worth it? - How much?
Discussion in 'General' started by SMIT, Feb 24, 2007.
  1. SMIT
    SMIT Donating Member
    Mornington Peninsula, Victoria
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Hey, i'm quite strapped for cash atm and i really cant afford $350 for each tyre on my vt, which im running 18's, when i bought the car the back tyres were retreads, i don't really see why people hate them so much, i cant say anything has gone wrong with them n the 6+ months ive had them, they grip fine in the dry and arn't too bad in the wet, They say they are speed limited to 140kph on the side wall, which is ok because i've never really done anything over 100kph, the only wear the tyre's have is from camber wear (one side is preety much bald and the other about 60% or something like that) So my question is why are retreads so bad? and how much do tyres cost to get retreaded?
  2. Reaper
    A retread is not as bad as a bald tyre however they are not great. You are required to put tyres on your car with a speed rating on the tyre placard (usually found on the drivers door) as a minimum and the retread will not be up to par.
    The short answer is yes - run it as a last resort untill you can afford a decent tyre.
    Cheers,
    Reaper
  3. rb26dett
    rb26dett New Member
    VT SS S2 A4
    Cant get a set of stockers for it until you can afford the tyres?
    And if your paying $350 per tyre your getting ripped off!
  4. AirStrike
    91' VN SS
    Mate the 140km/h speed rating is for the tyre pre retreaded. Retreads are not ment to exceed 80km/h. As said your getting ripped if your paying that much for a tyre..............I paid less for my 19's.
    Just get some good second handies for them, I got some when I had 18's on and I think I paid around $120 for two 18's fitted up with pretty good tread.
    Theres a saying they have where I get my tires from.............'Retreads are for Retards'.
  5. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    use it as a last resort and save up.
  6. Schmoburger
    Schmoburger Capt'n Kombi
    Jervis Bay, NSW
    '83 VH Vacationer wagon and '76 Volkswagen Kombi.
    Pretty sure retreads are also illegal on the front in any case now?
    I was talking to a bloke who drives the fire engine at HMAS Albatross and he said they are only allowed to retread tyres destined for the back wheels... fronts have to be new. :)
  7. Bravotwozero
    Bravotwozero New Member
    MY12 AMG C63 W204 Speedshift + 2013 KW T909
    I agree. Second hand tyres are a better option than retreads imo. One of the Foremans at work is always bragging how much money he makes and since I found out he put retreads on his VX, I've been giving him sh1t ever since! :yeah:
  8. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Retreads go out of round faster and can fly apart taking bit of your car with it. The advice to get second hand is a better option than retreads. The rubber on retreads are usually softer and not as deep as new ones. New tyres have a tread depth of around 8mm and the retreads are more like 6.5 to 7mm.
  9. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    my dad works there, was it him
  10. VLDavo
    VLDavo New Member
    lc torana. vn v8. ke30.mazda 1300.
    the only good thing retreads are for is burnout tires....... just save up for some good tires ... and 350 dollars for an 18 inch tire is a total rip off
  11. hakhawk
    never had a problem with the 15" retreads i used for a year or so, but anything bigger, id go second hand or new.
    i picked up my 18" tyres for around $160 each, nangkang ns2's, havent had a problem yet, some say theyre noisier on the road, but they not loud enough for me to get annoyed. only wear so far is really the camber on the front, theyre starting to feather a bit.
  12. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    There is actually a speed rating moulded into the side of the retreaded area. Usually 135 km/h. While retreads were pretty unreliable in the past, they are a cheap alternative to new tyres. I agree that they aren't as good as new tyres, but they carry the same warranty. If your tyre placard states a speed rating of 'H' or above then retreads are illegal. Bob Janes are doing an interest free period at the moment, might be an option to consider. $350 per tyre is a lot to pay, they must be very good tyres. If you can afford the best, buy the best but it tends to be overkill on a street car.
  13. greenfoam
    greenfoam New Member
    VP Executive R-spec
    I run remoulds on the back of my VP and I'd say I will continue to do so even though I have enough money to buy good tyres now. I go through a pair of rear tyres in less than 10,000ks so it's just not worth it for new ones. Plus the remoulds I can get hear are much softer and grippier than new tyres anyway. I don't think I would run them on the front just incase they failed and that the tyre wear on the front is much less, but I can't see them failing because they are made very well these days.
    If you like to enjoy your car and and don't do insane high speeds then I think remoulds on the back are the go, reusing resources is good for the soul too
  14. Bravotwozero
    Translation: If you like doing burnouts use retreads.
  15. Lloyd1986
    Lloyd1986 New Member
    VX II Supercharged S pack
    Personally enjoying my car would be hammering down the great ocean road, or through other roads in the otways. In which case you really notice the difference between cheap tires and good ones. So I personally would never use re-treads.
  16. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    There is a difference between a remould and a retread. A retread just has new tread that comes about 30mm down the sidewall where as a remould has a whole new outer casing of rubber that goes right to the bead.
  17. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    I had a set of remoulds on my old VN think they were about $60 each for 15x 215 they were a bit firm but the buggers lasted forever
  18. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    I'm gonna go against most here.
    Just get the Retreads.
    There was a guy that works at a retreading place that said they are speed tested to 200 anyway, but the government imposes the 140 speed limit.
    I've had retreads, remoulds, and new tyres.
    The new ones lasted a little longer, but i never had any problems with remoulds or retreads. Thats using them for burnouts, or normal driving. I bought a set of remoulds for $80, and they lasted just aslong as the nankangs i had on before them.
    But if your planning a trip somewhere, or as above you like the twisty roads, new should be the only option.
    Also 200 is the max you should pay for an 18, unless your bent on getting pirelli's.
  19. MikesVT
    MikesVT M&M =D
    Nothing :'(
    Recommended tyres for some cars (SS'/Libertys/etc) are more like $450 a tyre... You can get cheaper ones as has been mentioned, but i suppose like everything else, you get what you pay for.
    I'm pretty strapped for cash myself too and need some new tyres, I dont think I'll go retreds though, how long do they last anyway? I suppose its better than bald tyres, so as a last resort i suppose, otherwise save up! (much easier said than done, i know!)
  20. pr0n
    pr0n It's A Me ' MARIO '
    Gladstone
    03 VY II S V6
    350$ what a rip, ive seen ****loads of tyres for 18's for like 130 - 200 each
