Retro fit UC Torana with VT 304
Discussion in 'V8 Development and Modification' started by Rod Vermast, Dec 4, 2017.
  1. Rod Vermast
    Rod Vermast New Member
    Sunshine Coast
    VR Senator
    Has anyone on this page Retro fitted a 304 VT into an early Holden? Looking at VT 304 and auto into UC torana mainly concerned with wiring issues! Does anyone know of some one that can help with wiring on the Sunshine Coast?
  2. EYY
    EYY Well-Known Member
    VS Statesman
    Wiring's relatively easy. Just a matter of a few relays for fuel pump, ignition, power etc.
    Easiest to start with the 424 pcm and loom from a Vr-Vs v8 as the wiring is batchfire and much more simple, yet will still run your auto trans. You'll need to have a Memcal burnt to remove vats.
    The speedo will be the biggest obstacle. There are ways around it though - such as having your speedo modified to take the electronic signal.
  3. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    Use hq mount brackets on the engine it sits it back further than commodore mounts leaves more room up front for a radiator and fan
  4. losh1971
    losh1971 Well-Known Member
    VR Ute V6
    Would it be possible to fit an older electronic dizzy and ancillaries and run it without a PCM? Then instead of auto run a manual. I know this can be done on boats that run EL series Ford V8 Engines, thought maybe the same could apply in a car.
  5. EYY
    VS Statesman
    Yes just run the 808 ecu for the injection. The th700r4 from VN to VP is cable operated and doesn't require pcm/ecu input.
