Shounak
The Kicking Horse
- Apr 20, 2005
- 2,500
- 60
- 0
- Age
- 37
- Location
- Vic
- VX Executive S2 + XF Panel Van Project
Pulled the **** apart, couldn't find anything.. I bolted in the cruise module and hooked the cable up to throttle body.. That was easy..amcroft said:Just to add a bit more!!! The plug that fitts into the cruise module is a brown colour. And it should be located under the fuse box in the engine bay, windscreen end.... Hope this helps mate...
I looked for a plug/loom to fit into the cruise module. I even took off the bolts holding the fuses in places, lifted it up and nothing. I took out the battery and had a real good look around and could find f*ck all down there..
Pulled apart steering column and the VT Stalk won't plug into my VX, which is fair enough I guess. And easily fixed..
Are you guys sure the wiring is in place on a VX S2?
