Reverse Lights
ducatis
33
Lennox Head
VS UTE
Hey everybody, how has your weekend been? um to the point... on my VU the reverse lights do not work for either side, i had a look in it and the globes seem to be in good condition, not blown or anything. so i was wandering what could be some other causes, or is there anything i can check like on the gearbox to see if its connecting?
cheers mitch
wrx884
WA's ASR Rep
37
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
try using a multimetre on the contacts and see if there is ne current flowin through u may b able 2 pin point where the current stops then
hkmonaro68
vz wagon
If its a manual, disconnect the reverse light switch on the gearbox.
With the ignition on bridge the 2 wires together, if the lights come on, the switch is stuffed.
ducatis
33
Lennox Head
VS UTE
anyone know how to get to the switch on the gearbox?
cheers mitch
hkmonaro68
vz wagon
From memory, it up on the side of the box, drivers side, It will be the connector with 2 wires only,
bradwilks80
Reverse Light issues too...
Hi All,
I have a manual VT S pack.
The reverse lights are not activating when reverse is selected...
I have removed the cabin gear surrounds but can not locate the switch mechanism previously described.
I have tested the globes they are fine, however the power to the globe is not active at the globe connector plug.
Any help (& pics/diagrams) would be really appreciated.
VTPREDATOR
35
Warwick
VE SS SPORTSWAGON
the switch will be located on the gearbox itself, under the car
