Reversing lights not working on V6 auto....help??
6L SSV Writeoff
Airbags work really well!
VS S pak Ute SII
Wondering if anyone can help.
I've replaced the fuse for reversing lamps, I've pulled the switch apart that is on the left side of the shifter as per the "How to repair reverse light switch on Auto VR/VS commodore" in the how to section of this forum, still not getting any lights in reverse. The globes are definitely working as tested in other sockets...What else can I check?? Any help appreciated.:bang:
gobrien002
1995 VR Series II S
Have you checked the wires and connection to the globe?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Look in the boot where the wires come down alonside the hinge arms - it's easy for the wires to get stretched here.
ephect
Donating Member
VS Acclaim V6
first i'd be checking to see if i had power in the globe holder, then tracing it back from there, checking each plug for life. then you can work out if its rear loom or around the dash area
what else have you checked?
