How did you fix it?Thats more then likely your problem. I adjusted mine and now works fine.
I would like to know too. Mine does it. I'll put it into reverse and the lights don't work, but i pull it down a bit more and it clicks and the lights come on. I looked for the switch under the console but had no idea where it was or what it looked like either. Would be a good how-to thread if someone could do it cos it sounds like a common problem.where is the switch? under car? or is it under the plastic near ash tray? whats it look like?
