revs too high!
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by kwik6, Feb 5, 2006.
  1. kwik6
    kwik6 stroke it baby
    rowville, melbourne
    vz ss cobalt blue/ hk prem chev
    I installed a v8 throttle body onto a friends v6 vn today and for some reason even when the throttle is fully shut, the revs are sitting on around 2500rpm!!
    Ive tried to loosen the cable more but theres no point once the throttle body is fully shut i guess so does anyone know what else might be causing the revs to idle so high?? cheers
  2. Fully
    Fully New Member
    Vz Sv6
    one of the sensors on the tb i guess would be cusing it.
    the throttle position sensor (TPS) or the IAC valve.
    also make sure that all the vacuum hoses are on properly that would also cause it.
    good luck
  3. kwik6
    rowville, melbourne
    thanks mate i will have another look at it tommorrow.
  4. PaRaDoX
    PaRaDoX Because Racecouch...
    Melbourne, Victoria
    none
    do this, hold it up to the light when the butterfly is closed and see if u can see any light (if all else fails) it would probbly be the IAC valve because that determines the idle...
    take the car for a little drive, does it drive normally??? (ie shift gears fine?)
  5. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
    check to make sure all the gaskets are fine too, sounds like u may have a vacuum leak
  6. samuels
    samuels Active Member
    VX HSV XU6
    did you reset the ECU ?
    also high revs can be caused by an air leak...did you put new T/B gaskets on?
  7. kwik6
    rowville, melbourne
    thanks for all this info guys your great! everything is fine with the throttle body buy i havent had the ecu set after i installed it. might be that? didny put new gaskets in either since the old ones still looked perfect. does this matter??
    ps, what does IAC stand for?
  8. samuels
    VX HSV XU6
    sometimes it can be a problem,by not putting on new gaskets,as they are squashed down from a previous installation,if you reset the comp,don't rev it to 3000RPM for 10 seconds :).....theres no need to,even though people say it does and workshop manuals too,there is no need to
    IAC ......idle air control
  9. kwik6
    rowville, melbourne
    legend, thanks!
