Revs up then down erratically then stalls
MickT
VY SS
Hey, i have been having a little problem with my VP. One second its running great, then when i start it up again after ive driven it the idle/revs rise then drops n rise and drop erratically then when i put it in drive it stalls.Then i start it again and can drive away. Under load its fine. Changed injector seal, injectors are also good. The Throttle position sensor is new. Checked the coil packs and there good. Ive checked the car for codes and nothing comes up.
Anyone have any ideas? Thanks.
camstatic
I'm back babeh.
Regional SA
VZ SS
Check the MAP sensor, if that checks out, perhaps try cleaning out your IAC valve?
Pub247
Melbourne S.E.
Ford Fairmont
try cleaning the tb and iac valve on the tb might help
MickT
VY SS
I have also cleaned the tb and checked the iac valve forgot to mention that, ill give the map sensor a try next. Thanks guys.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
when you cleaned the throttle body did you by any chance let any carby cleaner dribble down the shaft into the TPS they dont like that.
MickT
VY SS
Nah, i cleaned the TB first then put on a new TPS. Could the fuel system cause such a problem?
camstatic
I'm back babeh.
Regional SA
VZ SS
I'm guessing the fuel pressure regulator could need looking at, for such a simple unit they're not cheap at all though. I paid cost for mine and it was still just over 80 bucks.
DrJeckyl
VN commodore S1 & VXII Berlina LS1
Might be way off target but my VN was doing a similar thing.
The rubber fuel lines inside the tank had perished, which didnt allow fuel to return to the little bowl inside the tank the fuel pump sits in.
changed the tank over been running fine since.
holden-4-life
QLD
VR Equipe II
see thats whats crap
computers cant tell u that stuff, something little but very annoying
