Richie's VT Exec - VX SS Kitted - A tidy 6 banger
Discussion in 'VT - VX - VU - WH - V2' started by rch-13z, Jan 17, 2008.
  1. devilly
    devilly Well-Known Member
    adelaide
    VT commodore
    Trust me better to grab brand new lines as i only just changed mine out. the new line is 3x smaller then the replacement line. as over time and heat they expand themselves and then you don't have proper pressure and the radiator level will be low all the time as it will not fill up properly. then you have air in your system and problems later on.yeah they are a bitch to undo on the firewall, after doing the trans line they seem like heaven to me now.
    surging vacuum sounds like under the throttle body to back of engine is leaking. when it's idling just move your hand around you'll find it easy that way. hope it all goes well and you find it. check around the egr as well
    rch-13z likes this.
  2. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VX SS 5.7L
    Im getting this sent to me mid week and next weekend Heater Tap will be off and replaced.
    https://www.ebay.com.au/itm/24-Flexible-Wire-Plier-Hose-Clamp-Flat-Car-Brake-Fuel-Oil-Water-Garage-20003063/182043763895?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    Its designed for spring clips, fits on the tabs and ya squeeze handles and locks in place so can easily remove
    And yes the spring clips are a real **** and so decided on this tool as i was not winning by hand or my small long nose pliers
    And i see you have same heater tap also, Gates i got.
    I had a look at mine and looks like the plastics are ok but near the vacuum solenoid area is leaking and dont trust it to last
    rch-13z likes this.
  3. rch-13z
    South-West Sydney
    VT Exec
    Rattle-can all the things lol - looks a ton better than the black bracket..
    Next thing I want to colour-code is my radiator cover...
  4. afstruct
    afstruct Active Member
    Warners Bay
    HSV VS Maloo , 2002 Monaro
    Color coding the rad cover should look really good. Love it, your car just looks so right
    rch-13z likes this.
  5. rch-13z
    South-West Sydney
    VT Exec
    Pulleys & Belts replaced, general service done, bunch of vac leaks fixed.... still have an issue with something like a miss at a particular rpm - possible tps?
    O yeah, and new plenum cover on - just needs a polish and shiny bonnet latch on.
  6. afstruct
    Warners Bay
    Nice, I love this car, it looks sooo good
    rch-13z likes this.
  7. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    Holy ****. You still have This?
    rch-13z likes this.
  8. rch-13z
    South-West Sydney
    VT Exec
    Lol 13 years this coming February
    Cruise for Charity done for another year
    Painted and smoothed radiator cover needs revision but it’s getting there - was all painted and cracked in one spot so some chopping is required
    _War_ likes this.
  9. rch-13z
    South-West Sydney
    VT Exec
    More cruise for Charity 14
  10. rch-13z
    South-West Sydney
    VT Exec
    Sooooo not much happening either than maintenance and painting bits.
    Front Rotors & pads done, this also revealed that my drivers calliper might be starting to fail so Im just waiting for a rebuild kit to arrive.
    Nightshaded a bonnet protector I got given a while back.... If it looks good then mad - if not I just bin it, no loss either way.
    LS1 radiator cover I smoothed & repainted cracked around the filler neck (didn't measure the height of the refill spot for the aircon properly) so I'm re-bogging & primering a majority of it to get it to as best I can...
    Other than that, just dailying as per usual.
  11. uniacidz
    Sideneee
    VX SS 5.7L
    Mate if you gonna bin the bonnet protector, let me know and can take off ya hands and some cash your way
  12. rch-13z
    South-West Sydney
    VT Exec
    Didn't turn out too bad, going to attempt to fit it up tonight
  13. rch-13z
    South-West Sydney
    VT Exec
    Fitted the new/old bonnet protector.... I actually like it - and it’s actually useful with all the driving I do.
    Went for a drive to the Gong to catch up with Brok from this forum - he snapped some purdy pics
    Also, sourced all the bits to rebuild my spare calipers.... will feel better when it’s sorted.
