Rims + Tyres Sv6 2010 Holden Commodore VE
Glack
Australia
2010 VE Holden Commodore Sedan
Hey guys whats up
Im looking at getting a set of Black 20" DTM shines for $1400 and finishing it off with a set of Kumho Ku31s looking around $760 dollars
I'd like to ask a question as to whether 20x9 front and 20x10 rear rims will fit on a 2010 Ve sv6 commodore
Thanks!
mikey-
Perth, WA
VE SS Sportwagon
Without knowing the wheel offset it is not possible to say if those wheels will fit...
With the correct offset, 20x9 can fit up front and 20x10 can fit in the rear.
Glack
Australia
This is the offset 20X9 FRONT 20X10 REAR
45-OFFSET FRONT AND REAR 5/120 66.8 CENTRE BORE
Glack
Australia
Ok sweet
Im kind of a newbie to car mods and things. Because the offset is 45 for both front and rear, i won't be able to fit tyres that are 245/35/20? or will it work? Sorry
mikey-
Perth, WA
VE SS Sportwagon
245/35/20 should be fine in the front, I'd put something wider like a 275/30/20 on the back though...
Glack
Australia
ok thanks for the info
im kind of thinking otherwise now about these rims, i want to get something that can fit same tyres back and front just in case of emergency situations etc
Sean880
VIC / NSW
2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
1. Make sure the wheels you are buying have the 5 x 120 stud pattern or they will not fit obviously. ( PCD 5 x 120)
2. I have seen the “experts” claim 2 different VE hub measurements – one being 66.9 mm. (the other 66.7). Check the hub size on your car because if it is 66.9 mm, the wheel with a 66.8 mm centre bore is not going to fit over a 66.9 hub. Many after market wheels have a larger centre bore than this.
3. 9 inch wide FRONT – a 45 mm offset wheel will fit and you can fit either a 255 35 20 or 245 35 20 tyre. The 255 tyre will have a slightly higher tyre wall (profile) but provide a little more tread width.
4. 10 inch wide REAR – with a 45 mm offset - you will need a 275 30 20 tyre for this wheel to give you the correct tyre diameter for the car and the correct tyre width for the rim. This fitment is going to push the package a further 18 mm approx out towards the edge of the rear guard compared with the standard factory set up on the SV6 with 18 x 8 inch wheels (48 offset) and 245 45 18 tyres. Most likely with full suspension travel the outside face of the tyre will scrape the inside lip of the rear guard . It will be a very marginal fit but I think you will find the tyre face rubs the guards with enough suspension travel. In that event you would need to have the lips on the rear guards rolled up so they did not foul the rear tyres. ( If you fit the 9 inch rims with 45 offset to the rear with 255 35 20 tyres you will not have any rubbing issues to worry about).
ducker85
Narnia
09 VE clubbie R8
HSV wheels are 20x8.5 +36P offset 245/35R20 tyres and 20x9.5 +57 offset 275/30R20. I just checked the E3 GTS's i pulled off my car yesterday!
use a online offset calculator to double check before you buy them if in doubt
