Ripshift and reverse...
vongy10
Gunnedah
CV8 Monaro V2
Hi all,
So I've had a Ripshift in my Monaro for a few years now and getting it into reverse has always been a pain. I takes more effort than it should and is always notchy, there are times where I really have to force it or even try a 2nd time. Are they meant to be like this or is there an issue with my install?
blackve76
47
there
VE SS ute 360rwkw N/A, 2016 VF2 SS M6
Had 3 ripshift cars and reverse fine before after, mate had a STD t56 that's was a bit hard to get reverse and would pop out of reverse std from factory(04 cv8)
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Never had any issues selecting reverse with mine
Only install issue would be not setting the stop bolt gaps correctly
Wouldn't hurt to check the bolts securing the shifter to the gearbox haven't come loose
vongy10
Gunnedah
CV8 Monaro V2
Was going to check the bolts but found out I need to undo the rubber surround from underneath the car... I'll give it proper look tomorrow.
VRStato64
Eastern Suburbs
VY SS II 6 speed
Any update on this I have a cheap ebay knock off rip shifter and its acting up particularly in reverse. Going to be doing the a complete ground up audio install so was planning on checking it out when I pull apart the dash and rip the seats out.
