yes music is dynamic but a peak is a peak in any sin/cos(/tan) wave.semi said:you guys are really only talking true AC sine waves rather than music. Music is very different to a sine wave, so you cant calculate the RMS from peak. The way manufacturers use peak is pretty much the largest DC signal that they can send for a very small period of time. Not the peak of the sine waves
vztrt said:If you mean RMS and peak than RMS is like the "average" of what the speaker is goin to be running. RMS is more a true indication (and not just in speakers, but power transmission etc).
The conversion is the peak power / square root of two (or peak power * 0.707).
StoneX said:Generally, they mean the same thing... When picking and choosing amps and speaker. They also use continuous sometimes aswell.
Technically, they are probably different.
1991_Vn2nV said:Nominal is a different rating to Peak. Nominal is similar to RMS but not the same....brands such as Pioneer use Nominal ratings for some of their speakers.
I havent been able to figure out exactly what the difference is but there is a difference. Pioneer claim that a 50 watt nominal speaker should be more powerful than a 50watt rms speaker as nominal is a lower rating than rms in general....but pioneer use nominal ratings alot so it may be bias? But then again they also use RMS
*shrugs* im confused
