Rocker Cover Gaskets
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by RoboticCherry-Coke, Feb 24, 2009.
  1. RoboticCherry-Coke
    RoboticCherry-Coke New Member
    Kadina, SA
    VS Calais S1
    Hey guys,
    So it turns out my rocker cover gaskets are leaking. Its going to cost me a ton to get them replaced by holden and i figure its something that i can do. Anyway what i need to know is do i need to use gasket goo for these ones and is there anything i should keep in mind or look out for when doing em?
  2. immortality
    Sth Auck, NZ
    these gaskets are re-usable. take the rocker cover off, clean the gaskets and put back on and tighten. no sealant needed.
  3. Troy5L
    Troy5L building a lemon
    Mornington peninsula
    Gu patrol td42
    if they are broken then just go2 ur nearest repco, autobarn, supercheap auto or bursons and get a set and put them on urself...2easy
  4. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    it is a very easy job mate, have you tried giving them a little extra tighten?
    make sure you have a small extension for your socket set for the drivers side rear most bolts though :p
    The gaskets are around $50 for the pair I think and a drop or two of silicone sealant doesnt hurt to ensure the gasket stays in place while you refit the rocker cover.
    I.E ad a few dots around and stick the gasket down to the cover, let it set for 30 minutes then do the refit.
    Sounds like a good oppurtunity to paint the covers :p
  5. RoboticCherry-Coke
    Kadina, SA
    VS Calais S1
    ah ok cool... yeah i went to sprint auto parts and its $16.50 a gasket but is it going to be worth it if the gaskets are re-usable... cheers for the info dannyboy, been thinking bout painting the engine cover as well so i may as well do the rockers to match :p
