MACE
- Mar 30, 2008
- 3,186
- 95
- 48
Why would you put longer pushrods in? Is there a benefit. I would have thought that a longer pushrod to the extent of not letting the rocker bolt down on a bigger cam wouldn't let the valve fully close on a standard cam. Maybe i'm missing something like the action of the hydraulic lifters.
There is a benefit of installing longer pushrods, to a certain extent, as it can increase lifter crush increasing the effective lift at the valve and also to quieten down lazy/noisy lifter.
Going too long though and it will cause the hydraulic lifter to act as a solid and even longer also keeps the valves open all of the time.
The base circle diameter of the cam we supplied is the same as the factory cam so longer pushrod's weren't required to correct any rocker geometry.
From my understanding the other pushrod set was used as one of his factory pushrods was slightly bent (?)
