Jesterarts
Your freedom ends where mine begins
- Nov 22, 2005
- 3,817
- 105
- 48
- Age
- 38
- Location
- Victoria
- 2010 Nissan X-Trail ST-L
Sounds like you're imply it there is all.
With a carby, it is better to have some temperature in the air to help atomise and combust the petrol.
It is better to be slightly warmer then what a car with EFI needs it to be.
If the air temp is right and the fuel atomises properly it will make more power then with "cold" air. It is possible for the fuel to pool in the manifold of a carbied car.
Ah yep, that N/A was supposed to EFI... that's one way for me to look like a retard.
And I agree, in a carby engine you the air as cool as possible so that the fuel "atomises" properly. But HOT air as what's his face said doesn't make more HP than the coolest possible air in the carby situation.
I think we're all essentially on the same page if we replace Bpefi statment that Hot air makes mor HP with something more along the lines of "In carby engines having the air as cool as possible without going too cold and compromising fuel atomisation makes the most HP" going hotter is going to drop HP because you won't get the most air density into the cylinder and going colder will cause a HP drop because the fuel won't atomise effectively.
Therefore, in the specific case of a carby engine, you want the air as cold as possible but the limiting factor is fuel atomisation. If this factor was to be overcome then the goal would be to get the air cooler again.
But in all cases, HOT air = bad.
Can we all agree on that? lol.
