vn calais manual
- Jun 22, 2005
- 785
- 2
- 0
- Age
- 35
- vn calais, vs clubsport #137
hey guys,
did a quick search but didnt really find much, ive got a set of YT 1.8 rockers and started installing them today, got a few qs for people that have done it before. might make me look stupid, but id rather find out for sure than something bite me in the ass!.
now,
q1) the yella terra steel plates they supply with the kit, do i need to use this? im assuming the plate goes on, then this small spacer with the bolt down the middle, but i notice in the drawing that them spacers are used on the adjustable types.? so i dont need this??, also. to put the plate on, all 6 rockers on that bank must be off at the same time, whereas the instructions ask u to do the rockers one cylinder at a time with the piston in TDC and continue in the correct firing order. so for me to fit this plate anyway id be going against the instructions?.
so atm i have just removed cylinder ones rockers, and sat the YTs on there and threaded the bolt in but have not torqued. should i be using a spacer between the cast for the bolt thread in the head, and the actual rocker itself, as the thread is visible and seems odd to me? but i could just be wrong. havnt really seen them before.
if anyone has any pictures of fully installed rockers it might help a little bit.
and if anyone has any tips let me know!.
cheers in advance.
now,
cheers in advance.
