Rory's 2006 Patrol
rory
Donating Member
Western Australia
2014 VF SV6 & 2006 Nissan Patrol ST
Vehicle
2006 Nissan Patrol GU4 ST
Engine
Stock ZD30 (non-common rail) (most problems in the ZD30 were worked out by 02, so 06 should be ok for grenading)
Gearbox
5 Speed Manual
Suspension
Stock for now
Brakes
Standard
Exhaust
Stock
Wheels
17 Inch Standard GU4 alloys with custom scratches :p and stock sized Bridgestone Dueller A/T's
Stereo
HU - Pioneer AVH-P8450BT
Amp - Alpine PDX-V9 5 channel
Front Speakers - Alpine Type R Splits
Rear Speakers - JL Audio 60 watt coaxial 2 way
Subwoofer - Kenwood KFC-W3012 (400w)
Modifications
-Steel Bull Bar
-Spotties
-Antenna for UHF
-Roll Bar
-Cargo Barrier
Future Plans
-Stereo from Crewman put in DONE
-Boost Gauge
-Pyro Gauge
-2 Inch Suspension Lift DONE
-Play tires (33 inch muddies/AT's) maybe on black steelies
-Upgraded Intercooler (current is weeping oil; an indication of a leak)
-Mount up compressor
-Inverter
-Draws system DONE
-Filling and painting interior holes Dash painted
-Fix blistered dash and replace worn steering wheel
-NADS (Nissan Anti-Detonation System)
Images
vrScotty
1994 VR Executive
ex mine car? looks it
corhijasna
51
Portland Victoria
looks good mate-great base to start
definitely recommend the anti detonation kit as a mate has a almost identical patrol except a 07 and he had to replace the head and all gaskets etc as she started to play up when 4wding, has since done a bit of work including the kit which monitors all temps,plus 2 diff temps for the block and one for the coolant and so far has been ok.
anyways don't want to ruin your day so good luck
iChris
Perthvegas
looks good. I bet it's going to take some getting used to being up so high.
what? do these things explode under normal use or something?
corhijasna
51
Portland Victoria
the 2.8's and 3.0 litres have a big reputation for blowing the 2nd or 3rd cylinder not sure which one but can be quite a costly exercise to fix,all the info you need should be on the net,
most are caused by overheating due to a small motor pulling or pushing a large amount of weight especially if using 4wd a lot or towing
rory
Donating Member
Western Australia
Yeah mate it is but it's in good shape.
Cheers mate.
Yeah boost and pyro gauges will be going on ASAP to at least get an idea on what's going on.
Not really for me, I've been driving my parents patrol since my learners so I know their size. Plus theirs has been my daily lately too.
Yeah the 00-01 were particularly bad, Nissan upped the sump capacity from 5 to 8 liters as a recall and there is minor occurrences past 02 but not very widespread compared to 00-01.
They tend to do it due to overboost and having high exhaust temps melting holes in pistons. The ECU was revised in 03 for better ECU boost control which fixed most problems. The exhaust gas recirculating to pass emissions testing also caused problems causing overheating cylinders particularly 3 and 4.
There's things that have to be looked out for but it's all fixable.
As above its pistons 3-4 but yeah that's pretty much it. Plenty of info on the net to stop it happening.
Sent from my iPhone
corhijasna
51
Portland Victoria
I knew yhe 3rd cylinder was involved somewhere-lol
sounds like you are in the know with all the precautions so have some fun-lol
rory
Donating Member
Western Australia
Started installing my stereo yesterday and plan to get at least most of it done tonight.
List for tonight is:
-run RCA's to rear amp location (in Rear quarter panel)
-mount amp in RQP
-terminate power cable into amp
-install ground cable
-use lighter socket for remote
-cut power cable and install circuit breaker
-cut plate to mount circuit breaker to
-run new speaker wires from amp into doors (drivers door is supposed to be painful)
-install speakers
-run USB cable to under dash somewhere
-probably more that I haven't thought of
corhijasna
51
Portland Victoria
get to it then chief-lol
sounds like you have the new car bug-lol
enroh
Regional S.E. QLD
VY SS UTE, 69 CAMARO!
Best nads is a 4.2. Just sayin.....
500rwhp corn juiced & boosted ls1
