rory
Donating Member
- Dec 1, 2011
- 212
- 2
- 18
- Location
- Western Australia
- 2014 VF SV6 & 2006 Nissan Patrol ST
Purchased a new roof top tent for the Patrol 2 weeks ago and put it on the following weekend.
Decided on the Featherlite T-Top due to its light weight and slimness.
Ran some power to the tent for a twin Narva USB charger and lights.
Decided on wiring an LED strip on the centre bar inside and a strip on the overhanging floor to light the ladder. Wired up 2 switches so that either will toggle both lights.
Also went on to rewire a lot of the rear of the Patrol since I was already half way there. Wired up a new fuse block in the draw wing with a new relay and relay block for the backup light. Also chucked some LED strip on my right side barn door in preparation for a rear door table.
Over the weekend just gone I got into building a rear door table.
Started with a sheet of aluminium that has been in the shed for years with dirt and corrosion galore and sanded it back to an acceptable level.
As I don't have a bender or a guillotine and I wanted this to be budget I used 20 x 20 x 1.5 aluminium angle from Bunnings for support around the edges and pop rivets to secure it to the sheet. I used 50mm hinges, 3.2mm stainless wire, and stretch loops from Bunnings as well. I grabbed some cable crimps from Jaycar and used them to hold the stainless wire to the table and the door. I put uncrimped M5 nutserts and washers in the panel holes that hold the trim above the door card to avoid drilling more holes than needed.
I had to trim the sheet down about 85mm width wise and about 45mm length wise so as I don't have the required tools, a star picket was used as a straight edge and a skinny grinder disk cut it to size.
Then It was a matter of drilling cutting and securing the sheet to the door
All said and done, for a shade over $50, I had a rear door table that is sturdy and can hold at least 1 Kelpie.
