Rotisserie help
Triff
41
Hobart
Ve ss
Anyone bought and used a rotisserie on there early commodore before? Can't find anything relating to mounting the car and Wether they come with mounting brackets or if you have to make your own. Any help would be great
Mike74ss
VF SS Redline SII
Hi there
Not specifically on commodores, but I currently have a lx Torana on a rotisserie that I purchased off eBay. No pre made mounting brackets are available that I know off and I ended up using some old bumper bar brackets to mount the body shell.
Good luck with your resto!
losh1971
North Tas
VE Series I SS Ute
Yeah mate from SA had a rotisserie for his SLR 5000. I'd say he made his as he was pretty handy with a welder.
Triff
41
Hobart
Ve ss
Thanks for the reply. Looks like I'll need some help with making brackets. Not sure if I'd trust vk bumper brackets as mount points. Not quite as sturdy as the old toranas
Fachoo
murrayee bridgee
calais 2
make your own angled bar brackets for under front apron to bolt to kframe front rail positions and under rear apron on boot floor rails. Easy rotisserie operation, strong and good access to work on.
Triff
41
Hobart
Ve ss
Thanks mate will be taking a look at it today
shane_3800
35
places
vr commo
Most sit on the ground, but if you need it higher you can mount it on the commodore. Just make sure the meat is well basted and you might have to add charcoal depending on the size of meat.
Triff
41
Hobart
Ve ss
Hahahhahah
