[SA] Rough gear changes
gen3vtss
adelaide
VT SS GEN3
Help please!
My automatic has a rough 1st to 2nd gear change and also clunks during the change,
Does anyone else have this problem and how do you fix this if possible.
rb26dett
46
VT SS S2 A4
Has it just started to happen, or has it always done it since you have owned it?
gen3vtss
adelaide
VT SS GEN3
i'm pretty sure it did it when i brought the car but not as bad.
I going to change the diff oil and add an additive and see what happens
cheers
vex
vx s2
Just been through the same thing. Luckily my local holden blokes not a bad egg and they did it for me just out of warranty.
Pretty much its due to holden using the same box for both the 6 & 8 without strengthening the guts of it.
Story goes (from a transmission specialist) that due to the amount of low end torque put out by the 8's it tears up the 2nd
gear band andmakes it slip on the shaft, and it only grips when it finally catches on, hence, the sudden kick into gear.
All they do is rip out the bands and replace them with reinforced ones (kevlar i think) andgenerally need to change the clutch packs.
I didnt see the bill but it would have been right up there!!
Tatiana
Administrator
Staff member
Land of the free
Equinox LTZ - runs on cocaine
Have you checked your transmission fluid level? If so I would recommend you book in for a service.
gen3vtss
adelaide
VT SS GEN3
Yeah i've changed the trans and diff oil but my diff contiues to chonk and chatter even after using redline
shockproof oil, in fact making it worst with a moaning sound during a slow turn.
cheers for everyones help.
