rough idle affecting tv reception????
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ringfeder3, Jan 11, 2012.
  1. ringfeder3
    ringfeder3 Active Member
    Nsw
    2017 colorado, 94 VR Calais, suzuki gsx1400
    I bought a cheap VS II ute to paint and sell. I strated it yesterday and it sounded like it was only running on five cylinders. As it had been in a yard for several months, I thought I would let it idle for a while. After ten minutes, my neighbour came and told me the car was affecting his TV reception!... I went in and had a look, the screen was all pixelated. I stopped the car and bingo, problem solved. When I started the car again, the problem recurred.
    Any suggestions?. Got me stumped.
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Sounds like the flux capacitor has started leaking.
  3. BowTie
    BowTie Active Member
    VS V6 Acclaim
    Sounds like it has spark plugs with no resistors in them.
    Ngk do resistor and non-resistor versions of their egv plugs. Its a known phenomenon that putting b9egv plugs in 250 2-strokes trashes peoples reception.
  4. ringfeder3
    Nsw
    Thanks Wraith, shame there are no DeLorean dealers in regional NSW...
  5. wraith
    Demonicaland
    As said by BowTie could be your spark plugs
  6. VR38
    VR38 Well-Known Member
    VB SL/E
    Cue twilight music; "Their out there"
  7. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    HT Leads.
  8. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    I want your car haha; cruise down the street affectin' everybody out there..
  9. VTSSDUDE
    VTSSDUDE Active Member
    NSW, Australia
    VT SS 5.7L Commodore.
    Definitely an ignition problem and your neighbour's reception issues are a sign that you have leaking voltage between coils and the spark plugs.
    Replace leads and plugs and you will be right, and of course so will your neighbour? (I wouldn't mind betting the issue is going to be a lead.)
    Or track down which cylinder isn't firing, replace that lead and plug first, if engine runs fine then see how your neighbour's reception goes. If you don't want to spend too much the car.
  10. ringfeder3
    Nsw
    Thanks, I'll give that a go.
