theking
Hi guys, hope everyone is enjoying their vacation.
I bought my car, and as always, I went ahead and cleaned body throttle. I noticed that the [ gallons/liter ] has fell down from being 2.5-3 at idle to being 1.5-2 also at idle. --> This is the small screen readings I'm talking about, I'm no sure if the actual RPM has fallen or not.
Anyways, I bought the Vararam cold air intake and installed it myself. After that I removed the negative battery cable for almost 2 hours, in order for the car's computer to reset and adjust to the new intake. Everything seemed good at first.
I went on a almost 800 km road trip, and as I came to a stop, the car almost started dancing, it idles really rough and almost loses power. I had that happen the first 200 km.
After I arrived, I took out the negative battery cable again for an hour or so. Car is in better shape, and doesn't idle as rough as it used to, but when the car is in the P or N position, you can feel the whole car vibrate. The RPM also rises up and falls down.
Car was in perfect condition before the intake.
On second thought, I think the car may have just a little bit of extra oil, car shop installed 9 liters of oil. I know that it only holds 8.3 liters. Could this be the problem.
Excited to hear your suggestions.
Thanks in advance.
Thanks in advance.
