Rough idle/missing after spark plug install.
SKNOT9
All hope is gone
Lobethal, South Australia
VS series II Acclaim
Hi there. I just replaced all the spark plugs on my vz and after that, it now misses every so often on idle. It will miss once or twice every minute or so, it isn't constant. It used to miss under heavy acceleration which is why i installed the plugs, its now perfect on acceleration but just does this every now and again on idle. Anybody got an idea of what it could be?
mike4226
gold coast
vz equipe 3.6
Does your motor make a ticking sound since the new plugs?
heyitsEnricoPallazzo
Big block Alloytec
VZ A4 Saloon
Are the plugs Bosch Platinum Fusion by any chance?
Did you install 2 new plenum/manifold gaskets?
SKNOT9
All hope is gone
don't think its the cat. and not bosch, got NGK plugs, didnt install any new gaskets, the one that was on there was not ripped or anything so i figured it would be fine, who wants to fork out 140 dollars for a gasket lol. Pretty sure its a miss, car jumps and engine makes a choking sound, but its not constant like i said. The motor doesn't make a ticking sound as far as i'm aware, what road are you going down with that one Mike?
