Rubber bit around centre tailshaft bearing.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Circlotron, Nov 18, 2011.
  1. Circlotron
    Circlotron New Member
    VP Exec 5L BT1 ex cop, ex taxi
    I haven't got under to have a look yet but I'm thinking the rubber insulator thing that goes around the tailshaft centre bearing has seen better days. Trying to track down minor noises transmitted to car body.
    Question - if I take off the half-circle clamp that goes around the rubber and bearing, does the rubber come off in two halves or is it a full circle, meaning the tailshaft has to come off?
  2. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    "I think" that the center bearing is one piece, so you shouldn't be able to pull it apart.
  3. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    Yeah you replace it as a whole unit, not just the rubber
  4. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    If replacing yourself mark the cv joint so you put it back together the same as it came apart, if put together in a different spot you change the phasing(forget the correct term for it) of the uni joints, they should be X amount of degrees apart...
