Rubber LPG mixer hose
Jezza91
East Gippsland vic
VT holden
Can someone please tell me where the rubber lpg mixer hose go too off a VT V6 please ?
krusing
Melbourne, Bayside
Is there a Fitting/Inlet/Outlet that is missing a hose ?
I am fairly sure the VX and VY Gas systems should be the same,
May need to get hold of the Service manual for the same,
They are floating around JC's on various threads.
jeepster
WA
VSII Ute
I don't know what brand of LPG mixer you have, but typically there is a small hose that goes to PCV and a wider hose that goes to electrically controlled valve between the mixer and converter. If it is Impco, they had extra hoses, I am not familiar where the spaghetti went.
vxcalais_01
VX V6 Calais 3.8 2001
Injector or mixer type ? One hose will be the coolant and the other gas. Take a pic. The hoses are different. There should be another for vacuum.
Jezza91
East Gippsland vic
VT holden
This is the hose I be talking about, can't fined anywhere for it to go? It is a impco lpg system. Car won't idle properly without it blocked off. Its running on petrol only as it hasn't ran on gas for years
vxcalais_01
Yes its the vacuum hose and sits under the throttle body (few inches back). It blows off quite often with backfires and will cause rough idling when not connected. The nipple can be in a different spot but I need a better photo. Take one under throttle and on each side closer. Is the plenum original to the gas system ?
