acarmody
Donati..Whoa Green
- Apr 29, 2007
- 5,920
- 56
- 48
- Location
- Brisbane
- VX Berlina
Basically what the title says.
I am messing around a bit with a little project. Basically I am using a computer PSU to drive a low powered amp, an Alpine MRP-F250. Now the 12v rail on the PSU is only good to 8amps but the 6x9s that I am planning on using are only 40wrms. so it should work OK. But the 12v rail is only putting out 11.5v for some reason, and just want to check if this is OK. I assume it would but better safe than sorry.
The yellow is the 12v line and ground is obviously black. I unsoldiered the other wires.
Also if I use an ordinary 3.5mm jack and use the two positives and split the negative, will this be OK to use as a high-level input?
