jproz
My attempt, still needs a couple of hose clamps to finish off and I'm not decided on how I want to have the drain setup.
Bracket isn't as OEM looking as I would've liked but didn't need much work either once I figured out how I was going to mount it. The bracket started as 200x150x25x4.5 from Bunnings and is cut across the 200 side after the first hole. It now measures 45x150 if that makes sense.
I ditched the Ryco supplied metal bracket which didn't look great when mounted like this and screwed directly into the circular bracket that holds the can. With the drain and easy access to the top, reckon it will be ok.
Hope this helps someone
