Hi guys, this question may have been asked before but i did a few searches on the forum and couldnt find an answer. I have just picked up a supecharged exhaust including cats for my N/A VX. Just wondering if there are any advantage to running the Supercharged exhaust over the stocker. Will the twin cats help with performance? Also will the s/c exhaust bolt straight up? Im pretty sure to the extractors are res mounting is the same but im unsure if the underbody mounts for the mufflers are the same. In a nutshell is it worth running the stock supercharged exhaust on a n/a commodore or should i just invest in a decent after market exhaust? Cheers
You would need to change the engine pipes as well to get the system to bolt up. All the under body hangers are the same. No, it won't be beneficial. A twin system on a stock N/A V6 will not perform.
