S pac ute LSD
Discussion in 'VY Holden Commodore (2002 - 2004)' started by one_and_only2004, Apr 19, 2008.
  1. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    is it normal for a ute equipped with an lsd to only have one wheel spinning? mine does it all the time - usually ending with me getting bogged out the front of work
  2. JD
    JD Donating Member
    Deep South, SA
    1.6L Turbo Holden Croooooooooooze
    either you LSD is worn out or maybe someone changed it to a single?
  3. nicko
    sa
    75 cruiser ute
    Jack the back end out the car up so both wheels are off the ground. Spin one of the wheels, if the other wheel spins in the same direction you have a LSD. If the other wheel spins in the opposite direction then you have a single legger. Also if you have a LSD it should have a tag on the diff that says something like "use only high performance lsd oil"
  4. one_and_only2004
    It is an LSD, she's got LSD stamped on it, and both wheels spin the same way. i just find it funny that only one wheel spins when it was sitting on the hill
  5. sp001in
    sp001in vyma100
    QLD
    VY ute
    my ute is an lsd v6 too, and i get the same problem.
  6. nicko
    sa
    75 cruiser ute
    The standard holden LSD is not all that flash. You can have them tightened though so they will spin two more often. Doesnt cost all that much just give a diff shop a call
