hi everyone, is there a way to take out ur glove box light bulb? im having trouble with my glove box it has come lose and some times the light comes on! and im scared i will forget about it and i will get a flat battery! And if i do take the bulb out this would mean there is no problem with it draining the battery? cheers
Just lever out the whole light fitting to remove the bulb. What's wrong with the glove box that makes it so loose, maybe the pin on the right side (inside the glove box) has come out.
Not if that globe is the cause of the drainage. See if you can find the big black plastic pin and put it back in, it might still be in the glove box.
