safe Ignition circuit VR exec
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Wozza, Aug 16, 2012.
  1. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Hi
    stupid question :) Im wondering if anyone knows of an safe place behind the center console to tap into the ignition circuit ?
    I need to run a relay that will be triggered only when the car is running.....These new fangled electronic cars scare the hell out of me :D.Thought I ask before I go poking around and let out the magic blue smoke
    Thanks
  2. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    trace the ign wire down to there it enters the fuse block. then go either side of one of the fuses. but choose carefully because if its something that draws alot of power you may need to up your fuse amperage
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    The fag lighter in the centre console should be ignition/accessory switched plus it has a big fuse and is easy to get to.
  4. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    +1 I have always done this
  5. Wozza
    VR_GS commodore
    Hi
    Thanks for the replies
    pretty sure the cig lighter is on the accessories circuit.....I need to have a power inverter on only when the car is running
    suppose Ill have to get under there with a multi meter :) cant make heads or tails from the crappy wiring diagram I have here
    thanks
  6. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    You could get your signal off the purple (i think) wire off your oil pressure switch, its the one that keeps the fuel pump powered up. Or you could even switch it off the fuel pump wiring.
  7. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    You won't need your multimeter - just pull the brown/yellow tracer wire off the end of the lighter and attach your inverter. The black wire on the lighter is earth.
  8. aussie4life11
    Western Australia
    just run a wire from your battery, to where you want the inverter. then inline place a 4 pin relay. standard will do. all you would need to do is cut it where it runs under your dash and put a female terminal connector onto each end that has been cut. then attach the female terminals to pins 87 and 30 on the relay (it will tell you next to each pin which is which). then run a wire direct from your on wire (ign wire). feed this to the relay on pin 85 and then an earth wire from pin 86 to the chassis of your car or any earthed section.
    using this method you will have direct power straight from your battery, so you wont have to worry about sucking to much power from the things that run from the ign wire, and it will mean that when the key is off or on acc it wont trigger the relay so it wont be on.
    if you need ill wire up one of my relays tomorrow with labels of each wire and where it should go as well as a view of the under side of the relay so you can see the pin layout.
    hope this helps.
  9. aussie4life11
    Western Australia
    he only wants the inverter to have power when the key is in the on position. eg cig lighter is powered off the acc so this wont work for him
  10. Wozza
    VR_GS commodore
    Hi
    Thanks.... thats basically what Im doing, Ive got a live fused(50 amp) 8 gauge run to the boot which terminates at a distribution block,I have the acc line/relay sorted(picked that up from the radio/cass) just need to get the ignition run connected to something under the dash ..Found a better wiring diag looks like the heater/fan is on the ignition side so Ill have a poke around there :)
    Thanks for the info
  11. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    I would do this.
    As you are running an inverter (to power something 240v I assume) it may draw a resonable amount of current when the inverter is loaded. Using the fuel pump as a trigger will virtually eliminate the risk of accidently flattening the battery by leaving the key on.
    Running a fused main supply directly from the battery is a good idea, don't forget to upgrade the earth all the way to the battery post. As you have the supply line running to the boot, you are already close to the fuel pump circuit, use the pump supply line to switch the relay.
    FYI pump will run for about 2 sec when the key is first turned on and then turn off if the engine is not running after that.
  12. Wozza
    VR_GS commodore
    Hi
    Hmmm thats a thought only issue is with the 2 sec shut off,the inverter is for powering a laptop for a carpc fitout so the current draw should at max be 10 amp .....Ive also got a pc controlled hd radio unit that needs power from both acc and ignition as the silly thing resets if power is cut (during engine crank) Im temped to run that directly from the bat as it only draws 0.06 amp when not in use, but I dont really like having stuff powered if not needed..
    thanks for the detailed info and to Andrew426 for the orig idea.....
  13. RX25SE
    Why not use a 12v power supply for the laptop (Im sure they exist) rather than running it through an inverter?
  14. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Cig lighter will work with ignition and acc on so should work.
  15. aussie4life11
    Western Australia
    hako, read my post again. he doesnt want it to be powered off of the acc circiut. hence why he cant use the cig power. it runs from the acc wire in the key is at acc.
    you are correct in that the cig is also powered from the on position.
  16. RX25SE
    Or.......
    you could open up the alternator and pick up the centre of the (star) winding. This should give you enough to power a relay only when the alternator is turning.
  17. Wozza
    VR_GS commodore
    Most laptops run at 19v 2 to 5amps, Im using a dc to dc inverter so its not as troublesome as a dc to ac 240volt and heaps cheaper :)
    So basically when on acc and starting the laptop runs of its internal battery, when the car running it runs of the inverter and charges the laptop batt
    Im kinda wishing I never started this project but it has a lot of potential once all the bugs are out :)
  18. Andrew426
    Yes a dc to dc step up converter is a far better option, I have one and it works well.
    Changing 14v into 19v is far easier than changing 14v into 230v then into 19v.
    Just be a bit wary of selecting the right voltage on the step up converter, my girlfriend started using a cheap chinese laptop power supply a couple of years ago and the display backlight failed 4 times (repaired each time) before she switched back to a genuine HP charger, and it has not been a problem since. I dont know for sure that the cheap power supply caused the fault, but it certainly looks that way.
  19. Wozza
    VR_GS commodore
    Hi
    Im using a cheap one MSY Online ..The lappy Im using is an old one that has been stripdown of monitor,hard drive ect and has been running of it for the last few weeks whilst the setup been running on the bench...If it go;'s pop Im not going to shed any tears :)
