sagging ceiling trim - how to fix?
J
judoman
Guest
I have a 1996 VS Commodore whose ceiling is all falling down. Someone told me that the basic idea is to:
1. pull out the plastic ceiling 'corner thingies' that hold up the ceiling, which will then come out completely.
2. scrape off all the old dead glue (little gold balls of foamy stuff) from the fabric and ceiling
3. use a can of spray-adhesive on one or both surfaces. stick it back up there, and replace the corner bits.
Is that an easy job? Or is it a lot more complicated in reality? The repair folk want to charge me $200 ... how long would it take to do it myself? How difficult is it? Any tips?
thanks!
Soybean
VR V6 5-speed
ive got the same problem with my vr i just sprayed some contact adhesive on it then put it back, it only lasted 3 days though:bang:
H
haynze
Guest
i think you should look around.. i got someone to fix mine with a whole new carpet for only 100 dollars i think it was
bezz
VK
just buy another one from a wrecker for less than 100, fixing it is more trouble than its worth
crazyspoon05
Penguin Whisperer
www.myspace.com
VW Golf GTI (RIP The 'Bizta' VNVPVR Wagz)
Got a near new roof lining for the wagz for $19 from a wreckers, much easier than fiddling around with regluing the old one, scraping all the foam off, etc
