Sat Nav map updates
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Afterwords, Oct 18, 2016.
  1. Afterwords
    Afterwords New Member
    Holden ute 3.6 Thunder
    I have just heard that the latest VE map updates have just been released to dealers.
    From memory the sd card on its own to purchase is $229 but when installed with a combined service its $169 ish.
    Not to bad as the last update map was way expensive.
  2. dans_vz
    dans_vz Active Member
    Albury
    MY16 VFII SSV Redline Manual & 05 VZ Calais daily
    Is this the MY17 maps? I think the MY16 only came out earlier this year, but good to hear that if they are still releasing new maps!
  3. mitchy_
    mitchy_ Member
    QLD
    Senator SV08
    Is if SD card only? My E1 Senator has a CD, with god knows how old maps on it.
  4. TazzI
    TazzI Envyous Customs
    W.A
    VE SS Ute
    Just thought Id confirm this,
    New maps are meant to be out in December :beer chug:
  5. dans_vz
    Albury
    Good to hear. Since Holden have been using "Here" maps as the supplier instead of who ever they originally used, seems there has been yearly updates
  6. LKR
    LKR New Member
    WA
    VE SS Ute
    How do you go about updating the maps? Is it simply purchase the SD card from the dealer and you can do it yourself or do they need to upload for you? My 2010 SS ute still as the original sat nav maps and they are shockingly out of date...
  7. Asmodai78
    Asmodai78 Member
    VE Calais V Sportwagon
    Take old SD card out and put new one in, it takes you longer to read this then what it takes to replace the SD card.
  8. dans_vz
    Albury
    Got an email earlier this week saying that the new map updates are out.
    $165 if done at same time as service or otherwise its $229.
  9. VS_Pete
    The last one was $165 to buy.
  10. dans_vz
    Albury
    Yeah thats right, I don't know why this one isn't that price just buying it on its own.
    Holden and it's dealers probably make more money this way I suppose.
  11. LKR
    LKR New Member
    WA
    VE SS Ute
    Are the updates available anywhere else besides the dealer ie. online?
  12. dans_vz
    Albury
    Not that I'm aware of....
  13. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    I was at the local dealer yesterday, forgot to see the parts guys about the map update.....
    dans_vz likes this.
  14. Chris1234
    Chris1234 New Member
    2012 VE Calais 6.0
  15. amc157
    amc157 New Member
    VE SS THUNDER
    have been to 5 dealers in WA and not one of them can help, seems as if you need to change to an after market unit if you want the latest maps.
    customer service at holden is deplorable.....
  16. Jennye
    Jennye New Member
    Mooloolah Valley
    VE
    Yes I've had the same problem. Disgusted with Holden
  17. JoshlikesCalais
    JoshlikesCalais Active Member
    VE SSV Z
    My Navigation doesn't even work! I think the SD card has come loose or something. It worked when I bought the car but now its says not installed, that Holden quality!
    Steve Heywood likes this.
  18. VS_Pete
    FFS push it back in
    lmoengnr likes this.
  19. Steve Heywood
    Steve Heywood New Member
    Melbourne, Australia
    Ve series 2
    I have the same problem with my VE 2...so I have to use my stand alone Samsung phone to get around...
  20. Fu Manchu
    Fu Manchu Active Member
    WA
    VZ V6
    I think retro fitting a series one console and getting the Alpine climate facia and CarPlay or Android auto set up is going to be a solution to what is a slow, bunky factory design in the series 2.
