Scan gauge ATF sensor
F1Aussie
North West Victoria
2011 VE SV6 COMMODORE
Hey guys, I recently got on OBD2 Bluetooth and I believe you can add sensors to the car scanner app if you have the correct PID codes. I have looked on the internet but cannot seem to find what I need for setting up the ATF sensor.
Does anyone know how to locate it and what fields need what when setting it up?
I will upload a screenie of the setup fields. Cheers
F1Aussie
North West Victoria
Fields to setup below.
lout
60
Langwarrin Victoria
why not just use dashboard engineering mode
F1Aussie
North West Victoria
I don't know anything about engineering mode. Not sure how many parameters they display. The car scanner is pretty neat though and allows a ton of customisation.
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
You get into engineering mode by holding down the scroll wheel button on the steering wheel while you start the car. One of the parameters in engineering mode is the transmission temperature.
F1Aussie
North West Victoria
So can you access engineering mode at any time then or just at startup? With the scan gauge you can check whenever you like.
J_D 2.0
Ipswich
You access it at startup but once it’s on the centre screen it stays there until you exit out of it. Once you exit out you can’t access it again until you stop the car and cycle the ignition again.
