ScanMaster and ELM327 on VZ Holden
alsweilerm
New Zealand
VZ Berlina Wagon
Apologies if this has been covered somewhere else, I've searched high and low and not been able to find an answer as yet...
I have a VZ V6 that is reporting Check PowerTrain and I'd like to use a scantool to pull the codes from the car. I've purchased a bluetooth ELM327 and also ScanMaster-ELM software. I can connect to the car using ScanMaster, but it only seems to have 4 parameters that I can view. No useful ones either. When I query trouble codes I get a message to say there are none - which can't be right. So I'm wondering, have I connected to the wrong module via the OBDII BUS? Or do I need some sort of VZ Holden configuration that I need to load into ScanMaster in order to read it correctly?
Thanks in advance for your help!
