Sandst4rm
- Jul 10, 2018
- 229
- 213
- 43
- Location
- South Australia
- VT S1 Calais Ecotec - VP Ute 3800
Just started up my fresh build S1 VN motor, primed up for about 1 min no plugs before starting and seems OK.
I have an oil light if i use the new oil sensor i bought but using the old sensor the light goes out straight away so maybe they sold me a ecotec sensor?
Checked for oil with sensor out and plenty of oil at the port.
I am scared a bearing will spin because im not seeing oil at the rockers and they seem noisy... I dropped just a bit of oil out the sump and not seeing any shiny boys in the film.
I checked cam bearing orientation before assembling the motor and all ports were in the right spot
I have upgraded to moly pushrods, new lifters, double valve springs and new retainers on stock cam, could they just be noisy? i put assembly lube on the rocker journals and soaked the lifters in oil
The rockers are just metal on metal ones they have no like cage needle things in the middle bolt part
It sorta sounded like it was knocking for half a second after warming up but now sounds good???
Thoughts??
Thoughts??
