Schneider SD660UI HELP!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Berliner, Mar 25, 2013.
  1. Berliner
    Berliner New Member
    NSW
    VT Executive S2
    Hey all. I literally JUST made an account on this site in the hopes that there is an angel on here who can help me with my wiring woes. I've got a VT Exec S2 and am trying to put a cheap Schneider sd660ui head deck in. I've cut the loom, downloaded diagrams, reconfigured the wiring 3 times, gotten a loom converter which DIDN'T FIT my head deck and am now at wits end.
    Is there anybody who can help me get this thing installed and working??? (I am completely new to this so try to dumb it down if possible)
  2. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    you will need to post up the schneider wiring colours and what they are supposed to connect to as I can't find a list for them
  3. Berliner
    Berliner New Member
    NSW
    VT Executive S2
    This is the wiring chart for the head deck. Thanks lout. I hope this helps you help me. Hahahaha.
    Power - Red (+)
    Memory 12V+ - Yellow(Fused)
    Ground (-) - Black
    Auto Antenna - Blue
    Front left speaker (+) - White
    (-) - White/Black
    Front right speaker (+) - Grey
    (-) - Grey/Black
    Rear left speaker (+) - Green
    (-) - Green/Black
    Rear right speaker (+) - Violet
    (-) - Violet/Black
  4. Berliner
    Berliner New Member
    NSW
    VT Executive S2
    I'm assuming I'll have to splice multiple wires from the VT to single wires in the head deck. I just can't figure out the correct layout for it.
  5. lout
    Langwarrin Victoria
    VX Executive S2
    Ok find the loom that went to your old head unit
    old loom ... schneider wiring ... function
    orange/black ... yellow ... memory always 12v
    yellow ... red ... accesories 12v
    yellow/red ... blue ... power aerial
    black/white ... black ... ground
    grey ... ... dash lights dim function
    grey ... white/black ... front left speaker -
    light brown ... white ... front left speaker +
    yellow/blue ... green/black ... rear left speaker -
    brown/black ... green ... rear left speaker +
    green ... grey/black ... front right speaker -
    light green ... grey ... front right speaker +
    blue/black ... violet/black ... rear right speaker -
    blue/orange ... violet ... rear right speaker +
    note there are 2 grey wires they will probably be different thickness one goes to speaker should be same size type as other speaker wiring
    there are other wires that control phone mute etc but not listed whether thay are 12v or ground
    make these connections and then see how it goes
    it is never as easy as the shop makes it sound, good luck
  6. Berliner
    Berliner New Member
    NSW
    VT Executive S2
    ^^^^ Does that mean function will happen once it's all hooked up? Sorry bro but as I said, I'm really new to this.
    Thanks for your patience.
  7. lout
    Langwarrin Victoria
    VX Executive S2
    function is what that wire will do so for instance your schneider unit does not have a dimming function for the display so one of the commodore grey wires will just be taped up
    if you know what each wire does it makes diagnostics a lot easier later on
  8. Berliner
    Berliner New Member
    NSW
    VT Executive S2
    Would it be easier to match wires if I splice it to the old loom before connecting it to the harness?
  9. lout
    Langwarrin Victoria
    VX Executive S2
    if you have a commodore adaptor harness, plug that into commodore loom,
    then look which wire adaptor would connect to, for example yellow on commodore loom may go to red on adaptor harness. lable this wire as accy or schneider colour
    then label each wire on the adaptor for function or schneider colour code
    then remove adaptor and splice into schneider head unit
    then plug it in
