screw through exhaust tip
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by fuzzy2308, Nov 1, 2008.
  1. fuzzy2308
    fuzzy2308 New Member
    Plastic datsun
    i was looking under my Ute to day just browsing and i noticed there was that my cheapo exhaust tip has been attached with a long self tapping screw it goes thou the back/bottom of the tip and in thou the exhaust i can clearly see the screw when at eye level, is this normal?
    thanks in advance
    fuzzy
  2. ImAHoon!
    ImAHoon! Banned
    Toyota Camry?
    yes, its normal for a cheapo exhaust tip with a screw through it.
    what kinda question is that? :s
  3. fuzzy2308
    Plastic datsun
    i mean like going in and through the exhaust, like they have drilled a hole in the exhaust. i just thought it was weird.
  4. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    I did mine like that with screws. Worked good for awhile but when I got the new uni's I just told them to weld it up, it vibrated like farkk with screws....sick of tightening them up now and then...
    I could of welded it up myself but I saw the welder sitting there at the mechanics and remembered luckly, and said "ya reckon you could weld the tip up for us?" Have never been happier every since. Improved the note a hell of a lot. It use to sound like a cheap high pitch crackle sort of thing (ricer, magna) when I gave it to it lol. SO JUST WELD THE ****ER! - Sounds much better than a tinny crappy thing...
  5. Ozzie
    Ozzie JCCC Warrnambool
    Warrnambool
    Ozzie'z Supercharged VY Calais
    They screwed it so it can be changed easily.
    Normally their tac welded and require grinding to change the tip
  6. fuzzy2308
    Plastic datsun
    thanx lads
  7. vnv8driver
    vnv8driver Banned
    Up your mum
    304 Calais
    if its a cheapo tip i would be taking it off, becasue evn though it looks like staniless steel, it will rust badly!! (talking from experience)
    I would go for a 50-60 dollar stainless tip from an exhaust shop and get them to tack weld it on to the tailpipe.
